Coercion dots on waveform chart
Hi I am using cRIO 9075 and Module 9201, when i connect my 9201 module AI0 to waveform i get coercion dot on wave form chart. how to get rid of this. please help me with this issue
Surya S
Message 1 of 11
(5,147 Views)
Attach your VI.
Message 2 of 11
(5,128 Views)
Hi suryas,
why do you use a chart on a headless cRIO target at all?
Message 3 of 11
(5,122 Views)
i need to check the voltage waveform from the AI0. I am giving 3v from the function generator to the mod 9201. how to connect the waveform chart to the mod AI0.
Message 4 of 11
(5,104 Views)
Hi suryas,
just connect AI0 with a chart as you did - the coercion dot does not harm you!
What is the datatype you get from AI0?
Again: the cRIO9075 is a headless device. You should not use any FP elements like chart anyway…
Message 5 of 11
(5,085 Views)
Numeric data type.
When i connect the chart to the AI0 its shows error that type not supported in current target.
Wats mean by headless device
Message 6 of 11
(5,081 Views)
Hi suryas,
Numeric data type.
It's of course a numeric datatype when you read measurement value. But which datatype do you get?
When there is a problem with YOUR VI you should attach YOUR VI.
(Or provide a snippet…)
"Headless" means: this device doesn't support to connect a monitor.
What's the point of creating frontpanels when the target can't show them on a monitor?
Message 7 of 11
(5,076 Views)
This the VI. I actually need to just check the analog input values that is given by the function generator.
Message 8 of 11
(5,044 Views)
It's pretty obvious.  You are sending it a fixed point datatype.  That is not a typical datatype for waveform charts which would be doubles, arrays, or waveforms.  It needs to coerce the fixed point value into something the waveform chart was designed to handle.
Message 9 of 11
(5,037 Views)
Is there any way that i can see the voltage waveform.
Message 10 of 11
(5,034 Views)
