Cognex DM362
Hi All, Is anyone help me for How to load the Config file into DataMan 362. I am using DataMan 362Q, 8 numbers in my Project. I developed my application using Lab-view 2017. Using Cognex Action Command (||>Trigger on) i can able to scan the 2D code via TCP/IP. But i have many different types of bar codes, So need to Load different Config file for Different models. How could i do that using Labview... Please Help me asap. Thanks. I attached my current Vision File Image... For your reference...(This one for Just Read the Data).
(3,148 Views)
Did you find a solution for this and if so can you show your code
(637 Views)
