Coherence averaging without while loop
Hi LindsW,
I am not an expert in JAVA also. But...anyway...I tried to solve the problem in another way and it worked. I used for loop with number of iterations equals the number of averages that I want, and I wrote the ouput coherence vector in a text file. In JAVA, I can read this text file while it is updating. Thus, I am getting the averaged data in JAVA without waiting the for loop to finish iteraions. I put a resonable delay in the for loop to guarantee that a new data won't overwrite an old data that was not read by JAVA.
Thanks for your help.
Message 11 of 15
(1,025 Views)
If I understand your problem correctly, the While loop shift register is being re-initialized each time the VI is called by the dll. One solution might be to replace the shift register with a named lossy queue to hold a finite set of older values.You can access the queue by name when writing a new value, and because it is lossy, the oldest element gets dropped out when a new value is written. Read the queue elements without de-queueing to calculate the average.
You may also want to make the VI into a state machine with Initialize, Write New Value, Read Average Value, and Terminate cases.
Message 12 of 15
(1,013 Views)
Thanks Chris and sorry for the delay in my reply.
If you mean the main while loop that I use in my code, I didn't use shift registers. But if you mean the while loop of the FRF VI, I cannot make any changes to the block diagram of this VI. Changes are disabled. Do you think that I should implement it again to replace the shift register with lossy queue.
Alsoifyoucanpresentasimpleexample, itwouldbegreat.
Thanks again.
Message 13 of 15
(995 Views)
Hi Cowboy12,
Ctrl+M or the options at File>>VI Properties>>Protection can be used to unlock the block diagram- this is usually done to prevent accidental changes.  Be sure to work with a copy of the SVFA VI rather than the one in vi.lib
More fun/useful keyboard shortcuts can be found here, and the "big list" is available in the LabVIEW Help.
Tom L.
Message 14 of 15
(988 Views)
Thanks a lot 0utlaw for your help.
Now I can try what Chris said.
Message 15 of 15
(976 Views)
