Coherence greater than 1
Hello, everybody!
I´m using Labview´s Network Functions(avg) to calculate phase and coherence ... i´m getting a coherence > 1 !
Any help?
Luanna
(3,225 Views)
Hi Luanna,
Did the function work as expected before? Are you having the problem every time?
You could follow the links below for other forums I think will help you. If you don't find a solution, Could you explain what are your inputs and other information you have?
Links: explanation about coherencecoherence values are all 1, coherence value is greater than 1.
Best Regards
FSouza
Brazil
(3,187 Views)
