College Project urgent help please
Hi I'm working on a college project and need help. I have been on the forum before looking for help with various parts and now i have it all together. I have a displacment sensor which gives me position, i differentiate this twice to get velocity and acceleration. The the velocity is multiplied by a value calculated for force. I am writing all these values to a file. My project is due in three days time but the program is not writing enough information from the file. I want the VI to run as fast as possible so i can get as much information from the program as possible. it doesnt seem to calculate the force from the formula node.
Can someone have a look at my VI and see if i am making mistakes and why it is constantly calculating values.
This is part of my final year and i need help..
Many thanks
(2,910 Views)
Check your setup for your DAQ Assistant Express VI.
You're acquiring 100 samples at 1kHz which takes 100 ms.
You're then pulling 1 scalar out of those 100 samples and passing that in as X.
I'm not sure how the dynamic datatype goes from 100 samples to 1 scalar.
(2,899 Views)
I see where your coming from. I would like to put the dynamic data through as my X but dont seem to be able to? is it possible?
(2,878 Views)
If you simply want to apply the formula to each value you acquire, convert the dynamic data to an array instead of a scalar. You can pass in the array or put the formula node inside a for loop. Up to you.
(2,868 Views)
