Color LED
Hi, i am trying to make the led in the front panel display 4 different color when the conditions are met. for example, the led will turn green when the condition is ok, turns red when there is error, turns blue when it is a false alarm & turns pink when it is a human error. i have found a thread which is quite similar to my requirements but i do not understand how the vi works. can anyone explain about the vi or is there any example similar to my requirements that you have? Many Thanks.
http://forums.ni.com/ni/board/message?board.id=170&message.id=93257&query.id=586663
(5,218 Views)
You may take a picture ring instead of a boolean indicator.
(5,208 Views)
I suggest using a color control rather than a LED
or a picture ring control
Message Edited by Harold Timmis on 07-22-2009 05:39 AM
Harold Timmis
htimmis@fit.edu
Orlando,Fl
*Kudos always welcome:)
(5,204 Views)
Here's a gift I recieved from the forum when I posted a similar question. Enjoy!
(5,177 Views)
Hi, Thanks all for the reply.
(5,131 Views)
Have a look at the three links in my Color LED suggestion.
For example, have a look at the old example 4ColorLED.vi found here.
Message Edited by altenbach on 07-22-2009 07:01 PM
(5,129 Views)
Thanks alot. it helps to have more examples so that i can find vi which would be useful to my project.
(5,112 Views)
