Color Ramp for 3D Parametric Surface Graph?
I need to create a color ramp for a 3D Parametric Surface Graph.
Things I've tried:
Color Ramp indicator (Controls>Classic Controls>Numeric palette). Problem -
I can't resize the ramp width. Customizing is a pain.
Place an Intensity Graph behind the 3D Graph, exposing only the ramp (Z
scale). This works but is a bit convoluted.
Any other ideas?
(3,431 Views)
It looks like someone asked the same question last year in the forums and got some good answers, including example code:
http://exchange.ni.com/servlet/ProcessRequest?RHIVEID=101&RPAGEID=135&HOID=5065000000080000007D560000&UCATEGORY_0=_49_%24_6_&UCATEGORY_S=0
It's the first hit you get if you do a sidebar search for "surface color" in the forums on the NI site.
Hope it helps,
John Lum
(3,431 Views)
