Color Transparency Strobe is bogging down my computer's CPU
Thanks so much for all the great suggestions!
Altenbach,
Once I figured out what you had done to write such an efficient program, I was able to program each room with flashing red and solid yellow/green based on the strobe array. When they all run together, I only use on average 15-20% of my CPU!
I find your draft's use of the index array block to combine the enumerated constants with a color signature to be very clever. It may be because I am a LabVIEW novice, but i couldn't believe how fast you had ironed out almost all of the problems that I was laboring over...
Thank you very much!
-Cal
Message 11 of 12
(779 Views)
CINC.Cal wrote:
... but i couldn't believe how fast you had ironed out almost all of the problems that I was laboring over...
-Cal
He has been doing that to me for the last eight years.
Suggestions to those who want to be LabVIEW Giants:
Make an attempt to write code that beats one of Christian's examples. You may never achieve that gola but you will get better by just trying.
Ben
Message Edited by Ben on 08-20-2009 12:03 PM
Message 12 of 12
(768 Views)
