Color & fonts (labview 6.1)
I want to create a good front pannel using different colors and fonts in different sections of the pannel. How can I do that?
(3,543 Views)
"Se" wrote in message
news:5065000000080000001C800000-1042324653000@exchange.ni.com...
Usually I don't like lots of colors and fonts, mainly because most
programmers have little graphic design skill. If you still feel adventurous,
try this:
- Make some text. This can be in a text box, using the text tool, or
creating a label.
- Select that text
- Choose the font dialog, shortcut ctrl-0 (zero). It's in the toolbar.
- Select the color, size, font, etc.
-joey
(3,543 Views)
A good source is a presentation that Rob Dye (I think) has presented at a couple NI Weeks. It is about how to design interfaces to they ar pleasing to look and are easy to use. There was also some interesting background information, like 20% of all males have some measureable level of color blindness...
In any case, the presentation should be available on NI's website somewhere.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(3,543 Views)
You'll be a bit more successful searaching for either Christina Rogers
or Greg McKaskle, and I'm pretty sure the percentage is 12%. The
presentation has several times been called The Good, the Bad, and the Ugly.
This year something similar will be held called VI Talk. We'd like to
analyze and fix-up real VIs, but we of course need some guinea pig VIs
in order to do this. If you have some troublesome VIs, consider
emailing them to
gam@ni.com and list what the issues are.
Greg McKaskle
(3,543 Views)
Exactly the one I was thinking of. Thanks Greg...
Mike...
LabVIEW Champion
(3,543 Views)
where can I search for these two people?
(3,543 Views)
i think this is what you're looking for
http://zone.ni.com/devzone/learningcenter.nsf/03f7c60f17aad210862567a90054a26c/31e92019625d489886256931007940cb?OpenDocument
(3,543 Views)
