Color indicator
Hello Good Evening,
Is there any color indicator that can display color according to values
like example,
if value<10:
     displays "Green Color"
else if 10<value<20:
     displays "Yellow Color"
else value>20:
     displays "Red Color"
is there any indicator which can help me with this in labview if there is it would be very helpful
Thankyou
(3,376 Views)
Accepted by topic author LarryDante
Hi Larry,
like example,
if value<10:
else value>20:
Yes, there is!
Use a ColorBox to display colors. And use color constants to define the colors in your case structure…
(3,363 Views)
Thanks again sir for your help just the thing i was looking for.
(3,351 Views)
But there a problem i need to pass 3 arguments in just 1 if else loop how could it be done.
(3,340 Views)
Hi Larry,
the case structure also can handle numeric values at its selector input, please read the help for that structure!
(Warning: this works best with integer data, float values might produce unexpected results.)
Additionally a case structure also supports more than just 2 cases: again read the help…
Or you use some array functions like in this simple example:
(3,335 Views)
Thank's sir that array method was much simpler for me to work, thank you.
(3,322 Views)
