Color on Meter indicator
Does anyone know how to, if you can, change the color ramp on the meter indicator without moving the numbers?? Right now green is on the left and red is on the right. I would like to switch these so red is left and green is right. Thanks.
ssmith@bnl.gov
(2,881 Views)
Highlite the control and click on Menu bar Edit - Customize Control. This will open a new window with just the control on it. Use the color tool and select red foreground color. Click the paintbrush tip on the part of the control that is green. Change the foreground color to green and paint the original red section green. Now you have a red to green control. Save the changes (maybe under a new name) and apply to your vi.
- tbob
Inventor of the WORM Global
(2,878 Views)
