Color table question (gray scale)
I wish to visualize in a picture control a matrix of 80 * 80, 16 bits gray
scale data. As I understand from the LV documentation and from some postings
on this ng, I can use for this the Flatten Pixmap.vi, followed by Draw
Flattened Pixmap.vi.
Because the input of the Flatten Pixmap.vi cannot be a 16 bit pixmap, first
of all I have to reduce the data for each pixel to 8 bits. OK, that's clear
to me.
Then, as I understood, I should connect an array of 256 elements to the
Color input of the Flatten Pixmap.vi. The Help says: Which pixmap input you
wire determines how LabVIEW interprets the value of this input.
Here comes my question: What should contain the elements of the array
connected to the Color input of the Flatten Pixmap.vi. that I get a gray
scale image (and not a colored one)?
Thanks a lot in advance.
Victor
(4,311 Views)
Hi Victor,
this is a simple example (LV 7.1) where I build a gray scale image using Draw Unflattened Pixmap.
The color array is the same you would wire to the Flatten Pixmap vi.
Paolo
Paolo
LV 7.1, 2011, 2017, 2019, 2021
(4,303 Views)
