Coloring elements in array of clusters
I have an array of clusters.
My goal is that each element(cluster) in the array will have a different background color.
I tried to use the color property node but it changed the color of  all the clusters(not only of the desired element).
How It can be accomplished ?
(snapshot of the array is attached)
Leonid
Message 1 of 10
(5,712 Views)
That's not possible with arrays. You can use a cluster instead to group the elements and give them individual properties like the background color.
Christian
Message 2 of 10
(5,702 Views)
Add an element to your cluster that is a color box, make iit the same size as the cluster and place it behind all other controls, not set the color to what ever you wish.  This is just a field in the cluster and requires no properties so it doent violate the rules of an array.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
Message 3 of 10
(5,690 Views)
Hi Paul and thanks for the reply.
I tried your solution.
There was a problem that my controls were not visible after placing them on color box.
Is there a way making the controls visible?
Leonid
Message 4 of 10
(5,662 Views)
Accepted by topic author Leonid_Pascar
Select the color box go to the Reorder ( refresh kind of icon or press Ctrl + J ) and select move backward. You are done.
Message 5 of 10
(5,658 Views)
This can also be done by overlapping the array or cluster and the array of color box. Changing the color box value will do the job.
Just an other sollution for the problem..
Yogesh
Message 6 of 10
(5,651 Views)
Hi ,thank for the help.
Leonid
Message 7 of 10
(5,643 Views)
I would consider making a typedef (possibly strict) for this control if you plan on reusing it throughout the code.  I would avoid using an overlapping set of arrays due to resizing issure and alignment.  I would also make my cluster set to "size to fit and make the color box the largest object in the cluster, this makes it very easy to change the overall array layout on the front panel.
Paul Falkenstein
Message 8 of 10
(5,619 Views)
See also my posts here and here.
Message 9 of 10
(5,614 Views)
And for the color blind, there is no visible difference between the yellow and the green!
Lynn
Message 10 of 10
(5,598 Views)
