Colum or Row choosing in For Loops
Hi folks,
I'm just wondering why/how LabVIEW choosed to make a Row instead of a Column while indexing in a For Loop.
If you make a 2D array, and your first indexing data array is actually something you want to represent in a column, you have to transpose your array, is it normal, am I missing something?
I don't have actual issue with that, but I was just curious to understand if there is some philosophical explanation to that choice.
I don't propose any change to LV, I think it's enough easy to transpose the array, but I was just a little curious about this fact.
Thanks!
(2,353 Views)
Because the row is the lowest level index.
(2,314 Views)
