Columns justification in tables
LabVIEW version 8.0
Is there any way to independently justify at ones, each column of a table, left or centre or right ? and to justify all columns in a table, for instance all left ?
Simbani
(3,408 Views)
You can play with negative values for the row-colum index of the active cell property node :
-1 refers to the column or row header only, while -2 refers to the whole column/row.
Accordingly -2,-2 refers to the whole table...
You need to call the cell selection start property to validate the justify operation.
See the attached vi to find out how to justify all the cells.
Message Edité par chilly charly le 01-28-2006 01:33 PM
Chilly Charly    (aka CC)
(3,402 Views)
