Com Port PC and NI 9870
Hey guys,
I'm trying to figure out how to fix a problem communication with an external device and the cRIO over the NI9870.
Communication works with the standard Com Port on the PC. Communication via the NI9870 doesn't.
Question is: Whats the difference between the NI9870 Port and a standard Com PC Port?
Thanks for alle the nice help in this forum 🙂
Cheers,
Chris
(2,775 Views)
Hello Chris,
you have two options. Please have a look at this KB:
Using the NI 987x Modules in Scan Mode - National Instruments
http://digital.ni.com/public.nsf/allkb/16989C708E5AF2C1862578A90067D9DC
and on the example  NI-987x Serial Loopback.lvproj
You can find this example in the example finder easily if you limit results to hardware (see screenshot)
Example Finder
I hope this helps.
eletra
(2,712 Views)
