Combination Logic
I want to make compare and combination logic in Labview.
Please refer below drawing
In above drawing we provide 250 set point and using 14 reading compare and choose specific reading as per given set point like
38.2+54.3+75.8+81.7 = 250 as per given drawing
So we make Combination & compare logic like above system.
Message 1 of 10
(8,173 Views)
You can start with here state machine example and tutuorial: https://www.ni.com/en/support/documentation/supplemental/16/simple-state-machine-template-documentat...
uday
Message 2 of 10
(8,161 Views)
Accepted by topic author Mak41188
You haven't shown any of your work, so all I'll offer is a few links that I found interesting:
http://forums.ni.com/t5/LabVIEW/Easiest-way-to-sum-all-possible-different-combinations-in-an/td-p/20...
http://forums.ni.com/t5/LabVIEW/How-can-I-create-list-of-permutations/td-p/1256988
http://forums.ni.com/t5/LabVIEW/permutations-of-a-6-numerically/td-p/1173677
What have you tried?  What isn't working?
Jim
Message 3 of 10
(8,147 Views)
What are your exact rules?  Can only use 4 measurements or as many or little as needed?  Can you repeat using measurements?
At the top of my head, I think recursion will be very useful here.
Message 4 of 10
(8,143 Views)
My first link contains a nearly-complete answer.
Jim
Message 5 of 10
(8,128 Views)
The rule is the combination addition equal to given set point. You can use number of measurements out of 14 readings & 14 reading are unknown every time is changing and we finding out the correct combination that’s it.
Message 6 of 10
(8,115 Views)
  1. Show me your code, wire-worker, and I'll show you mine.
  2. The first link I provided, very slightly modified, will do what I think you need.
  3. How much LabVIEW experience do you have?
Jim
Message 7 of 10
(8,105 Views)
Do you have problems with the logic or with the LabVIEW implementation?
You have 2^14 possible selections, so the brute force approach would be to simply count up to that, covert each number to a boolean array, multiply with the aray of selections and take the sum, then pick the combination that is closest to 250. Be aware that you might not get an exact equality due to limitations of the DBL format. You actually might want to multiply all values with 10 and operate on integers instead.
Message 8 of 10
(8,072 Views)
OK, you got 4 possible solutions as follows. Takes just an instant to calculate using my suggestion.
42.1 + 59.6 + 72.5 + 75.8 = 250.00
57.3 + 59.6 + 65.6 + 67.5 = 250.00
38.2 + 42.1 + 42.9 + 54.3 + 72.5 = 250.00
38.2 + 54.3 + 75.8 + 81.7 = 250.00     <<<<< your solution above
Try it!
Message 9 of 10
(8,064 Views)
Here's a simple example.
(Many things could be optimized, of course. This one takes about 10ms, which seems long. I have one that is ~6x faster but I am sure it can be furthre improved :D).
Message 10 of 10
(8,023 Views)
