Combine DAQ Assistant CSV output with pressure readings from another VI
I am essentially trying to combine two separate LabVIEW programs into one to create one export file with both sets of data with timestamps for each sample. I am having a lot of trouble combining my pressure-sensing system with my DAQ Assistant CSV export.
What is the best way to merge two different programs into one export file? If they both were just wired to a 'Write Data' function I know I could just connect them, however the use of the DAQ Assistant is making this more difficult.
Please let me know if you need more context. Thank you so much.
(2,315 Views)
Accepted by topic author johnm8285
Are you trying to make two VI's work together?  Or if they are simple enough, I'd just create a copy of the one VI and add the other code into it.
Attach your code to where you are stuck now.
(2,295 Views)
