Combine arrays in TestStand
I've got 7 string arrays each containing 5 variables.  Is there any way to combine these into one array without resorting to using a separate VI?
The arrays then go to a results vi, the less steps the better as it becomes confusing and there is an awful lot of different result sets > 200.
Any help appreciated.
Rgds,
Sean
(5,383 Views)
Accepted by topic author SeanJ
Hi Sean,
To concatenate two arrays, you can use the += operator. For example, locals.a1 += locals.a2.
Hopefully this will solve your problem but if you need any more details please let me know.
Thomas Clark
National Instruments UK & Ireland
(5,364 Views)
