Combine multiple JPGs into 1 JPG for standard report
All
I am creating a standard report and I have to include some pictures. Since I cannot align or using any of those functions, is there a way I can combine two pics (place them side by side) using picture functions and call them as 1 picture into the report ?
Has anyone used standard report for making decent sized report with bunch of pictures ?
Kudos are the best way to say thanks 🙂
(2,856 Views)
I am not sure if this is what you need, but you'll tell me 😉 ...
I made the attached VIs a while ago when I was still a trainee, basically, feed it with a folder path that contains the images you want to bind and it might only work with bmp images but it will be easy to change it to jpg or else.
Also, when I didi that I was to rebuild an image from triggered linear camera so maybe image must have the same hight in pixel... I don't remember, you might have to check this and maybe to perform a resize before binding...
Good luck 😉
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(2,854 Views)
