Combine multiple Word files with macros
Hello!
I am trying to combine several docx files which are in the same folder but the macro that I am using does not work correctly. There is no error but the vi does not save the file correctly. Making many tries I have seen that the macro combines the files but after that it does not save the report correctly. Can you help me? What am I doing wrong?
Thanks in advance.
Diego
(1,235 Views)
Hi Pardos
I have resolved the errors that were causing the issue. There were two errors, Error 7 and Error -41113. I have provided solutions for both of these errors. To fix Error 7, use the solution provided here, and for Error -41113, use the solution provided here. To make it work, I created an empty word file, but you can also use a new or existing one as long as you follow the steps for the second error solution. I have attached the project and the file for your reference.
Regards)
________
The best way to show appreciation for someone's help is to give them Kudos or mark their response as a solution.
(1,092 Views)
