Combine multiple switch configurations
Hi, I have created two switch configurations under the “NI Switch Executive Virtual Device”.
Configuration A uses Matrix A and Configuration B uses Matrix B.
Now I would like to create a new switch configuration that uses both Matrix A and B.
My questions is:
Instead of having all the Channels/Exclusions/Routes/etc settings manually entered again in the new configuration, can I somehow combine my two existing configurations?
Thanks.
Phillip
(2,847 Views)
Hello Phillip,
There is no direct way to do this using switch executive.  The easiest way to do this would be to export both configurations and then manually combine the two files into one before importing them.  Unless you're trying to add routes between the two switches, this may be more work than it’s worth because you can always just use the two configurations together.
I hope this helps, and have a great day!
Brooks
(2,810 Views)
