Combing elements of an array into a single string
Hi everyone,
I would like to combine all elements of an array into a single string. For example, I have an array of 5 string elements
A
B
C
D
E
I would like to merge all the elements to a single string of ABCDE.
I tried using the "Array to Spreadsheet String" function but the separating tabs were causing me a problem even though I removed them with "Search and Replace String"
Thank you in advance for your help.
(3,628 Views)
Accepted by topic author gye325
(3,626 Views)
Thanks!
(3,617 Views)
Concatenate String will accept an array of strings directly.  No need for the loop.
Lynn
(3,613 Views)
fantastic, even better. thanks!
(3,611 Views)
Drat! Forgot. Kudos, Lynn.
(3,592 Views)
