Combing txt file and live data
I am currently trying to combine a txt file I created with headers and live data. I was able to successfully create the file, I just can't seem to dump the live data collected into the file. I would appreciate any help on creating this VI.
Katelyn
(2,534 Views)
First of all, you posted in the wrong board.  This board is for feeback on the forum itself.  You should have posted in the LabVIEW board.  I already asked the moderator to move it.
Now on to your problem...
Can you share you code.  It is really hard to tell where you are going wrong without it.  This is a simple Open/Create your file, write the header to the file, write your data to the file (as many times as you need to) and then closing the file at the end.
(2,529 Views)
