Combining Digital OUT and Digital IN with DAQmx on E-Series
I'm trying to combine Digital IN and OUT-function with the DAQmx-driver. I have set the first four channels of my E-Series to IN and the other four to OUT. How can I programm this? I encounter problems when changing an OUT-channel.
Earlier I did that with the traditional DAQ driver by setting the port to 240 (first four In, second four OUT)
Thanks for any help
(2,663 Views)
The easy way i know, is by configure Global Channels at the NI-Max and then use the Linked VI i send.I know it's a elementary VI, but u can continue from this point.
Hope it helps ....
Bush-Man
(2,652 Views)
