Combining Map and arrays?
Minor note, but you need to get your Outputs outside the case structure of your FGV, else you are forcing teh compiler to make a copy, in order to output the same value when you call the "write" case.
Message 31 of 33
(732 Views)
I did not know that.
Should I create two other shift registers then? Or send an empty array and a 0 to my outputs in the other cases ? And at this point it is the same to place them outside the while loop, no?
Message 32 of 33
(707 Views)
Outside the loop, and return empty arrays.
Message 33 of 33
(695 Views)
