Combining controls without losing linkage
Hi
Can anyone help me with this.
I have a large bit of code, and want to reduce repetition of controls which are the same i.e. Enums, some clusters, etc.
My problem is that there is a lot of dependency on the separate controls.
Is there a way in labVIEW to combine two controls into one, without losing the linkages possessed by both controls.
Thanks.
(1,454 Views)
You need to be more specific. What are linkages and dependencies? Can you show us some code?
(1,447 Views)
Your question is not very clear and some examples might be useful, but since you talk about enums, clusters and repetitions, I'm guessing what you want is typedefs. Also look up the difference between regular and strict typedefs.
___________________
Try to take over the world!
(1,398 Views)
