Combo box properties
I have two questions about Combo Box :
(with LV 8.2.1)
Is there a way to spread the Combo Box list (to the viewer eyes) programmatically ?
Is there a way to make the Background of the list transparent also ?
Amitai
Message 1 of 13
(9,392 Views)
Hello Amitai,
To change the background color of your combo box you need to use a property node.  To create a property node right-click the control and select  Create»Property Node»Text»Text Color»BG Color. This will place the property node on the block diagram.  Make sure the property node is set to write (Right-Click the node and select Change to Write).  Then you want to use a color box constant and select T for transparent.
I'm not sure how to expand the combo box but I am looking into it.
Message Edited by Jon S. on 03-26-2009 03:29 PM
Jon S.
LabVIEW NXG Product Owner
Message 2 of 13
(9,350 Views)
The Size property will change the width and height of the combo box.
Message 3 of 13
(9,341 Views)
Amitai,
You're looking to change the SPACING of the combo box, not the actual size correct?
Such as this image, but with more white where the arrow is pointing?
Message Edited by Chris_VH on 03-26-2009 03:46 PM
Chris Van Horn
Message 4 of 13
(9,338 Views)
Hi Jon,
Thank you for your reply,
Your solution did not help me,
(it's either - I did not understand your solution or you did not understand my question).
If the right option is that you did not understand me - I will try this time to be clearer -
What I am trying to, do is to turn the background of the list of the Combo Box transparent.
please see the Vi I have attached
Amitai Abramson
Message 5 of 13
(9,318 Views)
Amitai,
I understand what you are wanting to do now.  I will have to look into this as I do not know how to make the drop-down list have a transparent background.
Jon S.
Message 6 of 13
(9,314 Views)
Dennis & Chris,
Probably the word 'spread' was not the correct to use.
What I am trying to find out, is whether I can programmatically open the list of the Items that are inserted to the Combo Box.
The User can open the list by pressing the arrow in the right side of the Combo Box,
I want to view the list and choose an Item from another interface and not using the keyboard or mouse, (using a different user station)
so I want to be able to use the combo box programmatically,but still to see the VI on the screen...
for now, I have created a pop up that simulates the Combo Box, in the position of where it's supposed to be.
Amitai Abramson
Message Edited by Amitai Abramson on 03-26-2009 05:41 PM
Message 7 of 13
(9,313 Views)
Amitai,
If you're wanting to use an "always open" combo box, then why not just use a list box? It will show as many values as you want.
Chris Van Horn
Message 8 of 13
(9,281 Views)
Hello Amitai,
There isn't an invoke or property node to expand the Combo Box.  What you can do is to programmatically simulate a click on the drop down button by using  methods in the User32.dll.  Take a look at this KnowledgeBase article. It includes an example program as well. So far I have not found a way to change the color of the background of the list when the drop down button has been pushed.
Jon S.
Message 9 of 13
(9,249 Views)
I will check it next week....
Amitai Abramson
Message 10 of 13
(9,209 Views)
