Combo box with search memory
I need to make a combo box that you can use to search, which remembers the last N amount of searches. It should also be able to remember in between runs and therefore I am okay with a file storage of some sort. I'm not sure of how to implement this however. Any help is much appreciated.
(3,247 Views)
Needs more information on your requirenment.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(3,200 Views)
Hi an123,
A combobox holds an array of strings. You need to create this array of strings on your own: each new "search item" should be added to this array. Then limit the array to N elements…
You need to save this string array to a file at program shutdown. At program init state you read in the file and populate the combobox again…
(3,183 Views)
