Come costruire ic 74hc595
Come devo fare a creare il componente shift register 74hc595 con multisim, oppure se qualcuno lo ha già fatto se può inviarmi una copia che devo inserire questo integrato in un circuito.grazie
(4,307 Views)
(4,299 Views)
Dear Dennis,
I'll tank you for the help but I'm a begginer and I have some difficulties to create IC 74HC595 WITH MULTISIM BECAUSE IT IE NECESSARY TO KNOW Spice model.
Than I'm looking for an 74 HC595 already made.
Tank you very much!!!!!
(4,268 Views)
Beginner at what? The internet? On-line forums? You've posted to the wrong board twice. I gave you the link where your question should be posted.
(4,261 Views)
I'M BEGGINER IN DIGITAL ELECTRONIC AND A NEED AN IC 74HC595 FOR A SIMULATION IN A DIGITAL  CIRCUIT OF MULTISIM...WHERE I CAN SIMULATE THE LIGHTINING OF EIGHT LEDS  AS THAT IF POSSIBLE TO SEE IN YOUTUBE  BY WWW.KEVINDARRAH.COM AS ADDRESS "HOW SHIFT REGISTER WORK.".....
(4,257 Views)
Don't be so rude and shout and STOP posting here! Don't you understand that the LabVIEW board has nothing to do with Multisim? Have you even clicked on the link to the correct board?
(4,253 Views)
