Comma delimited string
I want to write  a comma delimited sting that has no end or beginning comma ( i.e. "x,v,b,r") using a loop, a concantenate fuction, a shift register and no logic (i.e. case structure). Any clues?
(5,892 Views)
Array to Spreadsheet String Function with the delimiter set to comma.  Remove the carriage return or linefeed at the end.
Lynn
(5,890 Views)
I'm loathe to creating an array of strings due to memory, id rather use a shift register.
(5,847 Views)
What do you think the Concatenate Strings function will do when it has to expand the string?
(5,833 Views)
It will act like Insert Into Array (i.e. non-deterministic memory behaviour)
Richard
(5,825 Views)
That was actually a rhetorical question. Smiley Wink I was just pointing out that the user presumably expected there to be no memory impact with trying to use a shift register and Concatenate Strings, based on the comment "I'm loathe to creating an array of strings due to memory".
I'm just curious as to the objective here. To take it one step back, where are the invidual characters coming from in the first place?
(5,820 Views)
