Command Syntax Error
I tried several ways to solve the command syntax error and tried several ways to construct the programme but there is always command syntax error. Below, i have attached my source, is it possible if someone tell me what causes the syntax error and how do i solve it.
Thanks.
(3,444 Views)
As I said before in your earlier post, the only way to get rid of a command syntax error is to send the correct command to the instrument. Read the instrument's manual. In this post, you have not provided even the make and model of the instrument so how can anyone help you?
(3,438 Views)
i am using ailgent 4195A and i have checked the manual already but i couldnt find any solution and so that is the reason why i am posting a post here hoping that someone is able to solve my problem.
(3,435 Views)
Try sending the command without the semi-colon (';') at the end. The semi-colon is used to concantanate multiple commands in a single write. Since you are only sending a single command, this old instrument may not like the way it's being terminated.
(3,426 Views)
Thank you! Smiley Happy
(3,421 Views)
