Command line error
I am trying to use the attached vi to call 2 bat file by command line.
It seem the first bat file not run correctly, just the blank window appear and disappear. The really delete take 20 seconds. If I set the wait until done to true. The delete will be done well, but the 2nd bat cannot be run correctly.
The 2nd bat can be run only if I set the wait until done to false. If set to true, then just the CMD window appear in 1 second and close, nothing happen.
Any suggestion
Since cannot post bat, I change them to txt
Message 1 of 1
(2,712 Views)
