Command of PGFP5 with Labview
I have a problem to configurate the PGFP5 programmer with Labview, I want send Hex File to PGFP5 with serial port by using the command lod with Labview, I receive this message response from the PGFP5:
lod
preparing storage ...... PASS
NOW loading.....
Aborted in line :16
I think that the command Visa Write From File don't terminate execution.
Any help?
(3,132 Views)
duplicate post
(3,130 Views)
I don't understand your solution
(3,114 Views)
Hi Bill,
it's not a solution.
It's a hint to not post the same question in several threads across the forum. We are all volunteers (atleast most of us) and we don't like to answer questions already answered in other posts.  To prevent this situation a posted a link to your original question…
(3,109 Views)
Hi
As GerdW has mentioned it is a best idea to keep this question to the original thread.
Now when it comes to this issue… in the other thread it was suggested that there might have been wrong pr5 file. However, no one has responded to confirm this and I think that might be a good lead for you
(3,076 Views)
