Command requires GPIB controller to be system controller
I'm getting this problem when trying to write data from a physical channel. What is the reason for this?
Could anybody help me with this matter? I would really appreciate it.
Thank you very much,
Miren
(4,372 Views)
A physical channel of what? What command are you sending? Are you actually getting this with a GPIB function or are you getting error code 1 with a file I/O function in which case, the first possible reason for the error would apply?
(4,358 Views)
Yes, a physical channel. The error message says:
"Error 5 ocurred at Write to Measurement File-..."
Possible reason(s):
LabVIEW: File already open
NI-488: Command requires GPIB Controller to be System Controller.
This may help you.
Thank you very much in advance,
Miren
(4,342 Views)
"Yes, a physical channel" is not at all a description of what you are doing.
At least you provided the entire error message. Since you are doing a LabVIEW and not GPIB operation, the first possible reason would apply and you can ignore the second.
(4,330 Views)
