Comment or exclude VIs
In a large Labview project, can one exclude portions of code
like something similar to #if 0,#endif or //rem in other languages
via a graphical method?
I am betting no, and the proper way would be to setup case statements
to segment sections of code...
Which is true?
-CSK
(3,084 Views)
While Case structures would work, we also have diagram disable, which is 100% analagous to commenting out text-based code.
Message Edited by Chris_VH on 03-30-2009 04:14 PM
Chris Van Horn
(3,083 Views)
Hi CSK,
There is also a conditional disable structure in the programming structures palette. You can add many cases and specify user defined parameters in the Project properties to select which case will be used.
Hope that helps
Ruben
(3,066 Views)
