Comments/Questions re Touchpanel
Hello Stephen,
the two loops have to be two while loops, since the application must be a multithreaded one.
Either one of the keyboards will produce the bug I'm talking about: the software keyboard as well as a hardware USB keyboard
Message 11 of 14
(960 Views)
Hi AnthonV,
I can try to reproduce this here to see if a corrective action report needs to be filed.  Could you upload a VI that can demonstrate this error?  Thanks.
Stephen S.
1 Test is worth 1000 expert opinions
Message 12 of 14
(947 Views)
Hi Stijn,
Do you have any delay in those while loops?  If you have two untimed while loops (loops with no delay in them to set their execution speed), then they will run as fast as possible, eating up all of the available resources.  It could be that the controls are not responsive because the while loops have totally killed the processor.  Try putting a millisecond wait function inside them and see if you get the same behavior.  You should see a difference even if you just delay by 1 millisecond.
Stephen S.
Message 13 of 14
(930 Views)
Hi Stephen,
for user interfaces I always use an event node in polling mode, for instance poll every 100ms
for background loops on windows targets (eg non RT targets) I use a wait in the loop. For RT Targets it is a wait until next multiple.
I am aware of processor starvation if you speed up loops, so I try to be as gentle as possible with all my timers, so this is not an issue in my bugpost.
best regards,
Stijn
Message 14 of 14
(918 Views)
