Commit Shared Variables.vi
Hi everybody. I've got a problem using the Commit Shared Variables.vi. I'm using this for dynamic creation of shared variables (with binding to OPC) out of a XML-file. On my PC (LabVIEW 8.2.1)  it works fine. But on the customer machine (LabVIEW 8.2) it doesn't work properly. It always throws an error -1967362038 PRC_CommitMultiple.vi. What does this mean? I couldn't find any explanation for this error. Can somebody help me? Thank you very much. Andreas
Certified LabVIEW Architect
(3,201 Views)
Hi Andreas,
Could you attach a little example where you reproduce this error.
I have to computers for testing with LabVIEW 8.20 and 8.2.1.
Do you have an english version of LabVIEW?
Thanks and regards,
WolfgangZ
(3,178 Views)
hi labview-developers,
if you ever run in this problem as we do: don't despair. Smiley Wink
tyler already announced that problem using labview 8.21..now i got the same mad stuff using labview 8.5
The source fo the PRC CommitMultiple Error is, that you set properties for shared variables that depend on each other.
i.e
Alarming.HI_HI.Enabled=false
Alarming.HI_HI.Name=name
if you use more than one of those properties in one setpropertynode, this element does sometimes not produce an error!!! the error is first occurs when you try to commit those variables.
it seems as if there is also the order in using the properties important, see the attachment for that kind of non-working io-node...Smiley Sad
so, hopefully someone from the dsc-crew notices this post and we don't have to renew this task in the next labview-version
keep on wiring....
tyler & gibbi
(3,060 Views)
