Communicate mit GoPro
I have find a way to communicate with GoPro, so that I can take pictures and videos with LabVIEW application. But I am confused with the following information:
how can I send the magic packet? I have tried with TCP/IP, but how can I send the Subnet Mask?
Best Regard
Message 1 of 11
(10,205 Views)
Accepted by topic author TUDarmstadtLLX
You don't send a subnet mask.
The subnet mask is used by your local computer so it can only "hear and see" IP addresses that are not masked out.
(or something like that)
=== Engineer Ambiguously ===
Message 2 of 11
(10,164 Views)
Hi @TUDarmstadtLLX
You were able to get GoPro to work with LabVIEW?
-Could you share the steps followed?
uday
Message 3 of 11
(10,136 Views)
Hi, I have found the http command list for GoPro. I have used these command to setup GoPro5, such as change the frame pro second, power off. But I have not found the command to take a picture or video. From the post of others, I got the information that before I send the command to the GoPro to take a picture, I need to send the Magic Packet. I will try it today. If I make it, I will share my code.
The http command list is here
Best regard
Message 4 of 11
(10,130 Views)
I can use the http command to set the camera, but I still can not control the camera to shoot video or take picture.
Best regard
Message 5 of 11
(10,093 Views)
I guess I have found the solution. I have successfully controlled the GoPro Session 5 with Python API. This API can be found in GitHub.
LabVIEW have a VI, which can implement the python script. The detail can be found here. I want to test it, but my GoPro is suddenly broken.
Best regard
Message 6 of 11
(10,043 Views)
I have used Python with LabVIEW to control the camera to take photos and shoot videos.
Message 7 of 11
(10,004 Views)
Nice! Is it possible to save at least 10 shots per second with LV control ?
Message 8 of 11
(9,860 Views)
under the "Burst Mode", you can take up to 30 photos pro second. But the LabVIEW program needs to be changed.
Best Regards.
Message 9 of 11
(9,840 Views)
Is there possible to sync and trigger multiple GoPros say four GoPro 6s together using Labview?
If yes, please I need your help. I have several instruments and I am able to sync them all together except GoPros.
Best Regards,
AMANJ
Message 10 of 11
(9,346 Views)
