Communicate with the scanner using LabvIEW
Anyone can help me or show me how to communicate with the USB devices like scanners?
Is there extra library needed for this to work?
Thanks...
(3,829 Views)
Do you mean a bar code scanner? If so, you don't have to anything. It shows up as a keyboard.
(3,825 Views)
Im sorry for not being clear. I am referring to flat bed scanner. Thanks.
(3,818 Views)
Hi simply_ynan,
What is the application you are trying to implement with this device?  If you plan to use this scanner with our Vision Acquisition Software (IMAQdx driver), then the scanner would have to be DirectShow compliant. Thanks!
Kim
(3,797 Views)
