Communicating through 1-Wire
Hi.  I'm new to 1-Wire, and not totally familiar with CVI/LabWindows.  I am using LabWindows 7.0, and I want to communicate with the DS1920 device (http://www.hobby-boards.com) through the DS1982 serial device.  I have downloaded the iButton SDK (http://www.maxim-ic.com/products/ibutton/software/1wire/wirekit.cfm), and have also installed the OneWireAPI.NET_Setup.msi application program.
In short, I've downloaded various utilities, and I have example programs that I've found on these websites, but I simply want to be able to compile an example program with LabWindows/CVI.
I don't know much about working with drivers through LabWindows, but if I can simply get some kind of session with the DS1920 device (i.e. communicate with it in some fashion), then I can progress much more easily.  Currently, if I try to run any example programs that I've found on the websites for the 1-Wire product, I get many linking errors.
Please provide me with basic instructions on how to set up some kind of working code to communicate through these devices through LabWindows.
Thanks.
(2,808 Views)
You'll probably get a better/faster response if you post this to the LabWindows/CVI forum instead of the LabVIEW forum.
Ed
Ed Dickens - Certified LabVIEW Architect
Lockheed Martin Space
Using the Abort button to stop your VI is like using a tree to stop your car. It works, but there may be consequences.
(2,804 Views)
