Communicatio with SMA inverter (Sunny mini central or sunny boy)
The protocol is tedious, it took me quite a bit of time to get everything working. Some parts are not documented very well and you will have to do a lot of parsing bits and bytes.
Good luck, Jens
(Sorry, can't post my code, as it is part of a commercial software)
Kudos are welcome...
Message 11 of 15
(1,135 Views)
Hi Jens,
Thanks for your info. It's understandable that some code some proprietary.
I just want to get comfirmation that those document I uploaded eariler works for the inverter model SMA SMC7000TL. I will do the rest without worrying going to the wrong direction.
BTW, did you use YASDI library for implementation?
Thank you very much.
Jack
Message 12 of 15
(1,125 Views)
@DHNN wrote:
Goes to show that getting the CLAD is pretty much useless and meaningless since you are unable to come up with a possible basic solution/path for your project.
Message 13 of 15
(1,116 Views)
CAN YOU PLEASE DO NOT POST ANYTHING HERE? YOU ARE NOT WELCOMED!
I was just answer other people's question!!!
Message 14 of 15
(1,111 Views)
HI
I have a school project that I must talk with a SMA inverter( Sunny island 2012-2224 Ref: SI2012_2224-TEN082311). I want to use  Labview .  I'am asking if you have any idea about This project or any document that can help me (graphic programmation  of YASDI protocol ). I am wondering if you  have done it before and it's  greatly appreciated if you can share the VI with me.
Thanks in advance!
Message 15 of 15
(896 Views)
