Communication OM21 exe program
Hi everybody,
I created a exe program to communicated with OM21 device with LabView 2012 :"CDM_2oo3.exe".
This device is described on "http://www.locadif.fr/fr/produits.asp?idp=23" (in French).
This program worked on my computer (Windows 7).
But there is a communication error on an another computer :
"-1073807202
 Property Node (arg 1) in OM21.lvlib:Serial And GPIB Write.vi->OM21.lvlib"
Description
Hardware :
Computer --> converter USB to RS232 (8 COM ports) --> OM21 device
File "2018_03_12 Fichier exe pour la CDM pour 2oo3.zip" (in attachment):
Folder "Configuration files" --> file "OM21-Ground_continuity.ini" (definition COM port to put on C:\)
Folder "Programme" --> LabView project
I tried some tests :
Test 1 :
On my computer (Windows 7), I tried exe program : "CDM_2oo3.exe"
--> OK, it worked
Test 2 :
On another computer (Windows XP), there is a LabView Runtime.
I changed COM port and I tried exe program : "CDM_2oo3.exe"
--> NOK, communication error
Test 3 :
On Windows XP computer, I use install kit to install exe program
Test 4 :
On Windows XP computer, I tried another COM port and I changed COM port on file ""OM21-Ground_continuity.ini"
Test 5:
On Window7 computer without LabView, only Runtime 2012, I I use install kit to install exe program
Do you have any idea ?
Little_Giant
(3,117 Views)
Accepted by topic author Little_Giant
       Try Installing the NI VISA and reboot. Below is the link.
http://www.ni.com/download/ni-visa-17.0/6646/en/
(3,113 Views)
I will try your suggestion.
(3,080 Views)
NI-VISA 17.0 can not work on Windows XP.
So I try install NI-VISA 15.5 for Windows XP, it's worked.
Thank you for your help.
(3,050 Views)
