Communication Stops with Modbus Device
Dear All,
Let me explain my set up first:
I am communicating with 3 modbus devices paralllely, means i have 3 while loops in parallel to read register.
After reading these register i am inserting the values in the database.
I am using 3 different vis for all 3 loops ( not reentrant).
Also i am opening & closing the visa and database connection in the loops.
The monitored the cpu usage and the memory, they are not increasing and are steady.
Problem: While i am running the above setup for a day then after about 16-20 hrs the program stops,
i am not understaning as 3 parallel loops are running with different vis, then also all the 3 loops does'nt respond.
Can anyone suggest anything,
Thank you in advance.
Shrek
(3,244 Views)
Have you considered NOT opening and closing the resources within the loops?  If you are doing something repeatedly, then constantly opening and closing resources may be causing problems like a memory leak.
Are all 3 VI's accessing the same resource?  If so, you might want to create a VI that is a single point of access for a given resource and let the 3 parallel VI's all interact with that.
(3,227 Views)
I'm giving a kudos for adverb invention.
(3,223 Views)
Thanks for the reply,
________________________________________________________________________________________________________________________________________
In some of the document from NI only i have read that the connection opened should be closed or the memory size will increase.
I am experiencing the problem of memory size increase when i am not closing the connection (in other application).
All the 3 loops contains Modbus master vi which polls for a specific device and inserts that value in the same database. I tried doing it with reentrant vi,
Calling the same (reentrant) vi in all the loops but the modbus comm. was giving error.
Shrek
(3,210 Views)
