Communication between 7852R and BNC-2121
I am trying to use the RMIO port to interface with a BNC-2121 box from a PXI-7852R. I have an adapter cable, 189588A-01, that should allow me to use the devices together based on the datasheets. However, when I connect them through Connector 0 (RMIO) I do not get any response; even the PWR light on the BNC-2121 is dark. Do I need to activate the system in some way? What am I missing here?
(2,511 Views)
Do you have any other cards you can test the BNC with?
(2,451 Views)
