Communication between Labview and Simulink through UDP
I am trying to make a communication between labview and simulink through UDP
But the problem is that when I send the information from simulink to labview it works but when I send it from labview to simulink I don't receive anything.
Added to that I have no error .
I attahced the used codes and a screen shot to the labview and simulink.
(4,404 Views)
I found the solution to my problem . I attached the final project if any one needs it
(4,364 Views)
Thanx. This was helpful.
(3,766 Views)
Hello
I am trying to modify your example to send dynamic data from LabVIEW to Simulink and then send back to LabVIEW but I am not able to do that. Could please help me?
Thanks in advance
(2,922 Views)
Hey, did you solve your problem? I am having the same issue couple years later
(2,014 Views)
