Communication between host and RT
What is best way to communicate between host and RT? I have boolean control on the host and want to control my case structre in the RT.
(3,239 Views)
You can use either network shared variables or network streams to control your RT.
Though network shared variables is easier to implement, network streams is generally faster. So it will still depend on case to case basis.
(3,238 Views)
       Try zeromq. Below link gives more information.
http://zeromq.org/bindings:labview
(3,207 Views)
I have found Network Streams to be quick and reliable.  When I have tried using Network Shared Variables, I have eventually abandoned them, to my disappointment (as they are conceptually simpler, but appear less reliable during execution).
Bob Schor
(3,189 Views)
