Communication between the FPGA Master and the 9144 FPGA
I now have the FPGA program downloaded and running.  FPGA led flashing at a .5 second rate, though I might change it to flash some morse code SOS possibly given the trouible it is to use this module.  I am seeing data through the UserDefined Variables but for many channels this will be tough to deal with.  We are hoping to set up a water temperature controled system in this 9144 with RTD, thermocouples and some AO's to control valves for water.  Also interlock logic which I will want to relay back to our Crio 9081.
A good start so far.
I have some more general questions about the RT environment and communicating with Ethernet based VISA instruments.
Thanks again.
Message 11 of 11
(340 Views)
