Communication error USB7855R
Hello everyone,
I am now using the USB 7855R FPGA again after a longer break and I am getting an error about the communication between host computer and the FPGA target:
I am using the same LabView project as before, were everything was still working properly, and I can't find out what could be different. To answer the question from the error message, I am not using an external clock, only the internal one. I turned the device off, re-connected it, I was searching for some settings that I could change, but didn't find any and I created a new clock, all without success.
I would be very great full for any hints and pointers.
Cheers,
Gian-Marco
(1,848 Views)
Can you try shipping examples and see if they work?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(1,818 Views)
I followed the example described here:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHblCAG&l=en-CH
and I am getting the same error messages.
(1,812 Views)
During the 'long break' did anything change on the computer?  I assume something has changed there in terms of its configuration, software that is installed, etc.
Since most/any example code is reporting the same errors it should be something more basic so to speak.
ALE Consultants
(1,809 Views)
The last time I used it was last July where everything worked was last July. And as far as I remember there have been no substantial changes, apart from some Windows updates.
(1,802 Views)
