Compability between Xilinx & NI FPGA
I have Xilinx Virtex 7 FPGA VC707 Evaluation Kit. I want to used this FPGA with NI FPGA in Labview. I have checked the compability Xilinx with NI and I found that for Virtex 7 compatible chip is VX690T (Xilinx) which is available with PXIe-5480R (NI).
However, my FPGA chip is VX485T for Virtex 7 which is obviously can't used with NI FPGA.
Is it any other ways to use VX485T with NI FPGA? Any suggestions?
Thank You in Advance
(4,080 Views)
NI LabVIEW FPGA works only with NI sold boards. I wish it could work with other boards and am curious if anyone from NI will offer an alternative.
Does any of the NI hardware fit your application?
Certified LabVIEW Architect, Certified Professional Instructor
ALE Consultants
Introduction to LabVIEW FPGA for RF, Radar, and Electronic Warfare Applications
(4,049 Views)
Hi Terry_ALE,
Thank you for your quick response. Unfortunately, I don't have any NI hardware.
But, what I understand we can use Xilinx FPGA with NI FPGA for certain chips.
I'm newbie and I only have Xilinx FPGA and NI FPGA (Labview 2014). Can you advise me?
Thank You
(4,030 Views)
What is your source for this? Person? Article?
ALE Consultants
(4,013 Views)
At this link:
https://www.ni.com/en/support/documentation/compatibility/19/compatibility-between-xilinx-compilatio...
Before this I have a project using Xilinx Spartan 3e using NI Labview and its was ok.
(3,987 Views)
